Jair Gonzalez
Complex Profiles
Can I import complex profiles that are on Archicad 25 into Archicad 24?
"Save As" the file as an archive version 24 file.
Then you can use the Attribute Manager to Export those profiles into an .AAT file which you can then Import into any other file (version 24 or above).
Or you can Append/Overwrite from one file to another.
Or you can simply copy/paste a complex profile wall, column, beam, from that saved file to any other (24 or above).
You don't have to save an AAT file, you can open PLN files in the Attribute Manager Dialog to import their attributes.
