2010-05-09
		02:55 PM
		2023-05-25
		05:07 PM
			Rubia Torres
2010-05-12 01:39 AM
2010-05-12 03:26 AM
mihaibala wrote:Almost but from what I can see there are curtainwall faces which lean out of the vertical plane (overhang panels below) which cannot be done within a single mesh (a stupid limitation but ...). But you could of course split it into multiple meshes - I assume you intend to convert to solids using the mesh-to-roof tool?
P.S. I can do this with the mesh tool; I simply create a mesh and then I start dragging points vertically, higher or lower. I could replace the curtain with the mesh, but I don't know hot to rotate it to a vertical position.
2010-05-12 05:06 AM
