Complex roof editing
Hi, I'm pretty new to archicad, and having problems with editing a complex roof on Archicad 21. In this video: https://www.youtube.com/watch?v=CSNyWR57Ylk (from archicad 15) everything seems so easy, but I can't get any more options than to move the whole roof, multiply, mirror, etc. What I want to do is to move the node on the sides of the ridge and make a gabel on each side. Thanks for any answers.
Sindre
David Maudlin
Sindre:
A screen shot of what you are seeing might help. One possibility is that the Roof is part of a Group, and Groups are Enabled.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Link
Your options will differ depending on if the roof is Single-plane or Multi-plane. To edit the ridge and turn it into a gable will require a Multi-plane roof as shown in the image.
You can do it with Single-plane roofs also but you'll need to delete the hip and just edit the other two roofs.
Also if your roofs are grouped or hotlinked, this may also affect the editing options.
Link.
