Composite Walls, thickness
when measuring a wall, the thickness i set to the outer limits of the wall (including the sidings outside and inside).
I“d like the measure to show only the construction thickness inside the wall.
Does anyone know how to describe this in AC 8.1 ?
(Pardon my english by the way, hope this was understandable...)
Mikal
1 REPLY 1
Aussie John
In the composite setting for the wall select as the core you wish to be dimensioned. Im pretty sure 8.1 allows this to be done.
Cheers John
[/size]
