Composite wall with 1.5 centimeters covering?
I want to make a composite wall with 19 centimeters in width, and 1.5 centimeters in covering on both end of the wall.
Is this possible in Archicad ? It seems a 0.5 can not be entered as the thickness, only round numbers. Right?
thank you for the reply.
10 Replies 10
It worked perfectly. Thank you once again Dwight.
But what about this:
Erwin wrote:
You can define how many decimals and rounding up / down in project preferences.
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=...
save a preset once you are happy with the settings and then define this preset in your views.
Erwin I did not understand you.
By "rounding up" you meant: "Extra accuracy"? But that is not what I need. Extra accuracy adds more accuracy to the value.
