Composites' Skins Height Function
Hi friends,
Today i am trying to draw a detail drawing.
I used composite walls. At the plan view everything is ok. But at the section view i don't want to see the tile skin above the false ceiling height. Is there function or way to adjust it ?
i can draw them one by one but it is not very practical in many cases.
11 Replies 11
Aussie wrote:
Under some circumstances you can use Solid Element Operations to "strip" a lining from a wall above a ceiling
That's how I've been dealing with it so far. I'm still wroking it all out, but using the subtraction with upwards extrusion seems to do the trick.
That said, it would be great is the profiled walls allowed you to independently set the heights of each component.
ogabson wrote:
Is there a way to adjust line views in composites in different scales? Is there any scale sensitive walls, slabs, beams like doors and windows?
For example i don't want to show plaster and tile skin in the scale 1/100
but i want to show them in 1/50 or 1/20.
may be this is a new topic or new user wish. Then see you in a new topic
