Composites' Skins Height Function
Hi friends,
Today i am trying to draw a detail drawing.
I used composite walls. At the plan view everything is ok. But at the section view i don't want to see the tile skin above the false ceiling height. Is there function or way to adjust it ?
i can draw them one by one but it is not very practical in many cases.
11 Replies 11
Link
The best solution AFAIK is to use a complex profile wall and set your plane plane at a suitable height. Other workarounds include using white composite pens with special pensets, or even patches. Yuck.
Link.
Aussie John
Under some circumstances you can use Solid Element Operations to "strip" a lining from a wall above a ceiling
Cheers John
[/size]
Thank you friends,
i have a new question about composites.
Is there a way to adjust line views in composites in different scales? Is there any scale sensitive walls, slabs, beams like doors and windows?
For example i don't want to show plaster and tile skin in the scale 1/100
but i want to show them in 1/50 or 1/20.
I voted "Essential" because that is the only reasonable way to model e.g. insulated precast concrete sandwich elements used as external walls. (This is the standard construction technique in Finland.)
I hope I understood the question!
Some people now model these as three separate walls (inner shell, insulation, outer shell) and obviously synchronising doors and windows is not exactly easy and the result is not an object in IFC-sense. Or in any other meaningful BIM-sense, for that matter.
TomWaltz
Don't profiled walls already allow you to do this?
Tom Waltz
Djordje
Yes they do, but you have to re-create the profile for every case.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
can you "capture selected profile" to get what the composite already has in it? I never tried it, but that would be a pretty easy way to create a Profile from a Composite (if it worked)
Tom Waltz
Good point - I'm not that far yet! Must be explored, but it may not be quite workable.
One would, I think, want to do the initial modelling without much detail, then use parameters to change the walls to whatever the engineer (and the manufacturer) tell you. Grabbing profiles to, say, 500 wall elements may not be quite as straightforward.
The "three walls" approach I learned from an experienced ArchiCAD user as the standard procedure. (Of course I've used the same approach in VectorWorks and it is truly painful!)
Rick Thompson
An important component for this essential tool development is to tie quantities to each skin. Say a roof has exposed rafters... you need to reduce, or pull back, the core of the composite, leaving the decking and roof covering and joist (via roofmaker). This might effect the insulation quantities if the assembly is a vaulted ceiling... for an example.
This one tool improvement would be worth an upgrade price for me.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
