‎2007-08-26 02:29 PM
‎2007-08-26 03:42 PM
‎2007-08-27 07:40 AM
‎2007-08-27 02:43 PM
‎2007-08-27 05:08 PM
‎2007-08-27 05:32 PM
Petri wrote:Don't profiled walls already allow you to do this?
I voted "Essential" because that is the only reasonable way to model e.g. insulated precast concrete sandwich elements used as external walls. (This is the standard construction technique in Finland.)
I hope I understood the question!
Some people now model these as three separate walls (inner shell, insulation, outer shell) and obviously synchronising doors and windows is not exactly easy and the result is not an object in IFC-sense. Or in any other meaningful BIM-sense, for that matter.
‎2007-08-27 05:38 PM
TomWaltz wrote:Yes they do, but you have to re-create the profile for every case.
‎2007-08-27 05:57 PM
Djordje wrote:can you "capture selected profile" to get what the composite already has in it? I never tried it, but that would be a pretty easy way to create a Profile from a Composite (if it worked)TomWaltz wrote:Yes they do, but you have to re-create the profile for every case.
‎2007-08-28 07:51 AM
TomWaltz wrote:Good point - I'm not that far yet! Must be explored, but it may not be quite workable.
‎2007-08-28 04:59 PM
