Consistency
Djordje wrote:
If you want to join the split chain again, or any two chains for that matter, select one and CTRL click the other.
Gee, consistency would say this should also work for joining walls...
2 Replies 2
Speaking of consistency...
Linear dimensions and angle dimensions that have their text placed between the dimension lines act differently. If you move the text of the angle dimension, the 'hole' in the dimesion line moves with it (just like it should). However, if you move the text of a linear dimension, the 'hole' stays where it is, completely ignoring the location of the text.
Djordje
Hmmm ... let's see ...
Unify does not work on walls.
Offset ellipse is not an ellipse.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
