Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Constrain with no shift key?
Hi can any one get a constrainment of a line or wall or moving an element without pressing a shift key?
5 REPLIES 5
Only if you are using the guide lines or you are snapping to the grid.
Or using the tracker or co-ordinates palette by typing in an angle and distance.
David Maudlin
Manuel:
In addition to Barry's methods: option-x, option-y, option-r and option-a will constrain to those axis (x, y, r, a).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi Barry, regarding the guide line method, if I click and drag in the direction I want to go I do get a line with a half circle showing up sometimes showing that the object being moved is in a straight line. You are not talking about this when you say guide line method are you? I have to have the guide lines turned on and then drag in the direction I want to go and wait for a guide line to show up and follow that, is that right? I have not tested that method yet so what do you recommend?
So long as your guide lines are active then as you start to drag you will get a guide line passing through the point you started to drag from and in the direction you want to go.
Thanks Barry I will give it a go
