Controlling the display of openings in RCP View
Any suggestions on how one can change the opening from dashed line in plan model view to solid line in a reflected ceiling plan view. I'm sure that there is a simple solution to this within the model view settings.
1 Reply 1
Eduardo Rolon
Check your Model View Options, as long as you are using AC13 or 14. Save one for each type of view.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
