ā2008-11-02
06:12 AM
ā2023-05-23
03:07 PM
Rubia Torres
ā2008-11-02 06:16 AM
ā2008-11-02 11:00 AM
ā2008-11-02 04:49 PM
fields wrote:Did you try 89.99 degrees?
well, ive tried using a 90 degrees roof and heh, the result is pretty bad. so that is a nono.
ā2008-11-08 03:57 AM
ā2008-11-08 04:16 AM
ā2008-11-11 05:09 PM
fields wrote:Well ... half the sphere would be better, as it is not faceted, but if it works for you ...
thanks for ur suggestion. I tried to make a custom window using slabs as the frame and a dome roof for the window.
