Coordinates
I have to reinstall ArchiCAD v10 and I'm forgetting many basics I haven't used in years.
During my recreation of Keyboard Shortcuts, I inadvertently assigned R to a command; thereby, losing the ability to use it as a coordinate to lock in the chosen angle yet select a specific distance; e.g., dragging a line perpendicular to another line a specific distance of 2'. I can't figure out how to reprogram "R" for this function. Any ideas?
Thanks in advance,
ArchiCAD v10
Macbook Pro
7 Replies 7
I was going to suggest that if you don't work it out, D does the same as R in that situation (if you can retrain yourself), but maybe not in AC10
Thanks for the tip on the shortcut D; but unfortunately, I also reassigned the function of "D".
Try re-assigning the R key to the Radius/Distance command.
This is the one it was assigned to originally.
I can't locate where the Radius/Distance can be programmed under the root menus; e.g., Edit, Design, Options, etc..
I think I may be able to relocate a previously saved Keyboard Shortcut file in a backup but I don't know where to find the file either. I searched under the Graphisoft folder and I don't find anything suggesting the Shortcut Scheme file. I even assigned a new Keyboard Shortcut to a command I'll never use, saved it, and then did a search for a file on my harddrive with the time of saving hoping I could locate the file in a round-about way but the change was not revealed.
Use the "List all commands in alphabetical order" option in the work Environment.
David Maudlin
Go to Work Environment > Shortcut Schemes > Keyboard Shortcuts. Change the List to All Commands by Theme, then open the 13 Numeric Input folder and scroll down to the Radius/Distance command to change its shortcut key.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David and Barry...that did it!
