Copying View Sets between files
With all the Organizer flexibilities, I would have thought that we could copy view sets from one file to another, but I have not found a way of doing so. Does anybody have a solution?
The problem is that my file might be corrupt, as it is behaving irrationally, and I would like to see if putting the contents of the file into a fresh template would solve the problem, but I have an entire project of view sets that would be extremely difficult to replace.
Eduardo Rolon
Try this, on a copy of the file;
1. Save your current project as a PLA.
2. Open the PLA and for the library setting select read from file.
3. Save as PLN.
4. Close the PLN, reopen and relink the library
___
Sometimes saving as a PLA removes corrupt objects from the file. If not you can delete everything from the file (a copy of course) while keeping the already define Views and use this file to merge the project from the previous one.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
