Use of Complex profiles for walls instead of composites
Does anyone see any reason not to use basic complex profiles set up to stretch both vertically and in width for our typical exterior walls? I like the fact that you can build the wall around the reference line and when changes are needed latter in the design they can be done without worrying about the location of the wall core moving on plan. Plus this method will allow us to use one complex profile for several stud thicknesses.
Jody S Keppers
It sounds like a good idea to me. I'm starting to experiment with the idea a bit, too.
Using different profiles does allow you to differentiate them in plan (with a different fill, for example) so that different wall thicknesses have different appearances. It would also make it easier to keep track of different wall types if you do automated takeoffs or schedules based on them.
Keppers Design Architecture
AC user since 1997 - currently AC 27
Mac Studio 2022, 64GB, 8TB SSD, Sonoma
MacBook Pro (15 inch 2019), 32GB, 1 TB SSD, Sonoma
iMac 27" retina display (late 2015), 16 GB, 2TB hybrid drive, Monterey
