Corner Windows
Is there a specific way to insert the corner window. it seems that I have luck sometimes but most times it takes a long time before it actually works?
4 REPLIES 4
I have found that for some reason I can only insert corner windows in a 2 x 6 wall, I then change the wall to whatever size is needed.
Grant
Grant
I do this also.
Link
A corner window *should* be able to be placed anywhere in a wall, then it will snap into the nearest corner. It's always worked for me, no matter what the wall is.
Link.
What's a 2 x 6 wall??. Like Link, I have had no problems regardless of wall type - except with AC8.0 which required editing after placing
