Service alert: BIMcloud SaaS disruption in the US Read more
Corner window criteria in schedule
Niranjan Das Sharma
In a thread it says that i can select corner window criteria for schedule but I am not able to find it in the available options! Where can i find it?
8 REPLIES 8
Ricardo Lopez
Hi @Niranjan Das Sharma
You are right, apparently there is not such kind a Corner Window element type, nor a proper Archicad classification for it, so if needed maybe you could create your own branch within Opening/Window and manually assign it to those singular windows in order to use it as a criterion for your schedules. Any way they will appear as individual windows.
Best regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Oh Ok. Thank you let me try this.
But here Barry says
That post was from 2017, I guess things have changed since then.
I just opened version 22 (the oldest I still have installed) and it is there.
In version 28 it is no longer there.
I'm not sure exactly when it disappeared.
It was still there right up to version 27.
Its not there in 28, even when you choose 'Show More'.
The strange thing, I created a schedule in 27 with criteria for 'corner window'.
I then opened that file in 28 and it appears fine in the schedule criteria scheme, but still not in the drop down list.
So that could well be a bug.
mthd
Not a carry over from the new 28 global library set up I hope ?
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
I don't think so.
Loaded libraries should have no effect on what we see in the schedule criteria.
Ricardo Lopez
I just checked and the element type dropdown list does not include the corner window type, but that element type value actually exists when added to the schedule.
It could be a minor bug to be solved in coming hotfixes. I wish... 🤞
You would have to report it to your local Archicad support.
Graphisoft may not pick up on it here.
