2025-06-10 04:11 PM
In a thread it says that i can select corner window criteria for schedule but I am not able to find it in the available options! Where can i find it?
Solved! Go to Solution.
2025-06-18 04:58 AM
I have also reported it in the 29 beta, and made mention it is not working in 28.
You can also export the schedule from 27 an import it into 28 (I haven't tried that but it should work).
The problem is, you just can't create a new corner window schedule.
You have to import one from 27 and then duplicate and amend it if you want a variation of it.
2025-06-23 01:12 PM
Workaround looks a bit complext but Thanks .:-). ..! I am using a perpetual version of 28. Will I get an update if they do some change?
Thanks
Niranjan
2025-06-24 03:09 AM
If they do fix it in an update, then yes, let's hope that they do.
Make sure in your work environment you have set it so you will get notifications of updates.
Otherwise, you will just have to keep a look out.
2025-09-15 08:46 AM
28.2.2 update Has fixed this issue! insatalling the update now. Thank you verymuch!!!
