Don't forget that the floor plan is not a true projection of the 3d building.
There are actually 14 'levels' that fills can be displayed on. Elements as standard display only on the middle six. This page details how they work fully.
http://www.archicadwiki.com/Display_Order?highlight=%28Category%29%7C%28Bugs%29%7C%28TechNotes%29%7C%28FrontPage%29%7C%28Category2dDrawing%29
It is symbolic and so this lets you do stupid things with the display order. For example you can bring the fill of a wall over a the top of a roof, even though the roof may actually be much higher.
I think this is an annoying weakness and needs to be addressed in future versions of AC. Another annoying 'feature' is when you adjust any settings of an element it brings it front of any other element on the same level.
The simplest way to solve your problem is to think logically. Reset the display order for all the elements you have adjusted.
Try bringing the bathroom fixtures forward one step at a time or send the tiles back one step at a time until they display properly.
Remember you are not moving the object, you are adjusting the order in which the fills are displayed.
If you still have problems, post a screenshot here so people can see exactly what you are refering to.
(Btw I have wished for changes here -
http://archicad-talk.graphisoft.com/viewtopic.php?t=16424
Please vote if you feel it would be useful or not.
Pete.
