Create an Arched Cornice using profilemaker?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-11-27
09:26 PM
‎2023-05-25
06:07 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-27 10:06 PM
A drawing window will open.
Draw a profile (a section cut view) of what you want.
Pay attention to the fills you are using.
In C.P.s, it's all about the fills and their edges.
Any lines you draw are only guides, they don't show.
You will then extrude (stretch) that C.P. out on your plan.
Takes a bit of practice but you'll get it.
Hope that helps a bit.
lec
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-28 12:51 AM
RichardAndrews wrote:Do you want something curved with the arch like the attached image?
I want to create a 6" tall x 3" deep cornice over an arched opening in a wall. Help!
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-01-28 03:19 AM
Ralph wrote:RichardAndrews wrote:Do you want something curved with the arch like the attached image?
I'am not the person how makes the question, but I have the same problem, and yes, I want something like your attached image, How can I do it?
I was trying with complex profile, but I can't make a vertical arc.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-01-28 10:32 AM
You can't make it vertical, but you can rotate it saving it as an object
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-01-28 11:37 AM
Jorge wrote:Do the free trial with OBJECTiVE to see if it suits your requirements. I made the arch by doing the following (referring to the attached image):
- 1. Open an elevation view of the wall where the arch is to be placed. Draw the cross-section of the arch profile with a fill and create a section profiled object with
OBJECTiVE > Component > New Profile.
2. Place one of the new profile objects across the arch.
3. UseOBJECTiVE > Tools > Bendto shape the profile to the arch
4. Use the profile setting to extend the start of the arch (for the straight vertical section)
5. UseOBJECTiVE > Tools > Splitto cut the apex of the arch
6. The finished result.
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-09 05:44 PM
Essentially, I just want to create a custom profile that I can curve vertically to create a curved architrave at the head of a window.
Cheers folks...
Chartered Architectural Technologist
AC23, i5 3570K Processor, 16gb RAM, NVidia 570GTX Graphics Card, 250gb SSD Drive
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-09 05:56 PM
griggadee wrote:You could try it with morphs – with some prework it should be quite easy, I think.
Are there any other methods for creating this, without using the cadimage plug-in?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-09 06:12 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-01-09 10:43 PM
griggadee wrote:Try Eric Bobrow's video here: https://www.youtube.com/watch?v=_EGdK-D7zXY
I don't see how I can extrude a custom profile vertically to form a curve. I am not clued up on using morphs. Any example videos you can recommend?
AC26 (since AC6.0), Win10
