Create an Arched Cornice using profilemaker?
I want to create a 6" tall x 3" deep cornice over an arched opening in a wall. Help!
13 Replies 13
Richard wrote:
Try Eric Bobrow's video here: https://www.youtube.com/watch?v=_EGdK-D7zXY
The profile around a door is from about 15 minutes in that video.
Another method is to trace the shape of your opening with a fill, cut and paste the fill it into the plan.
Create a complex profile wall or beam with the profile shape you want.
Place this wall or beam around the fill in the plan.
Select the walls/beams and convert to a morph.
Now you can rotate it in 3D so it stands up and move it to your opening.
griggadee
Thanks guys! Morph suggestion and the video helped me crack it!
Much appreciated.
Paul
Paul Griggs BSc (Hons) MCIAT MCIOB
Chartered Architectural Technologist
AC23, i5 3570K Processor, 16gb RAM, NVidia 570GTX Graphics Card, 250gb SSD Drive
Dontknow
Use the morph-tool and draw it into your wall opening.
Made a video of it.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
griggadee
Spot on Dontknow. Really great video!
Many thanks,
Paul
