Creating Line types
Does any one out there know how ( or if ) a person can create an entirely new line type? Or is there a way to change an existing line like the cold water, prop. line, etc. to have a different letter? Thanks. jeff.
I use A/C 11.
12 REPLIES 12
Dwight
Yes.
Menu Options>Element Attributes>Line Types
You'll want to create your new line on the floor plan, copy it and then open the dialog.
Create a new symbol type line and then paste the artwork in.
Adjust the spacing to suit.
There's a weird scaling thing going on that others can help with since the sizes change... you'll see what i mean.
Dwight Atkinson
Well, i can copy & paste the line segments, but not the Letter. Any suggestions?
Dwight
Draw the letter with line segments
Dwight Atkinson
Ahhh, Much Better. now I can have some fun.
Dwight
Mid-July.
Summer.
Creating new line types at workstation considered "fun."
Hmmmm.
Let me get back to stripping paint. Now THAT is fun. Heat gun much safer than blowtorch.
Dwight Atkinson
Well, yes. Fun is stretching it a bit. It is just a super low energy day and I don't wanna do my real job..... Shhhh.
Try these threads for an explanation of the correct scaling needed when exploding the 3d text library part and pasting the lines as a new line-type -
http://archicad-talk.graphisoft.com/viewtopic.php?p=28757&highlight=text+line+spline#28757
http://www.archicadwiki.com/TechNotes/Drawing_Curved_Text?highlight=%28linetype%29
Stress Co_
W.O.T.(way off topic)
Dwight: Not missing any feet, are you?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
I recommend you to visit the following ArchiCAD wiki articles to read more about custom Line Types: http://archicadwiki.com/LineTypes and Curved Text using Text 3D object: http://www.archicadwiki.com/CurvedText
Regards,
Katalin Takacs
