Creating Stairs Through a floor
Sorry its a long one!! but if anyone could help me it would be amazing....
SITUATION
I have an existing building which has a split level basement floor and a split level ground floor (it's very complicated)!
There are 4 storeys -
Storey -2 Lower basement
Storey -1 Basement
Storey 0 Lower ground
Storey 1 Ground
PROBLEM
I have built a new stair starting at storey -2 lower basement finishing at storey 0 lower ground. (it is not connected to any other floor) It is correct and the 3d model is fine. On the plan its wrong,
is there a way of customising which level the stair is shown - i have tried all the settings 'show relevent storey' etc. I want it showing up on -2 lower basement and 0 lower ground but I can't get it to show up unless i put it on 'show on all storeys', which i dont want to do
I hope this makes sense please get in touch with any advise/tips/ the answer!
Many thanks guys and girls
CHRIS
E:chris.stow@hotmail.com
Erika Epstein
Unfortunately not. You will have to break up the stair in sections to get it to appear correctly.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
chris:
Or just add a white masking fill over the stair on the stories that you do not want it to show on.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erika Epstein
When I've seen this question about stairs and not wanting to see it on story it passes through, it raises several questions.
- in archicad and similar programs, the goal is to model all the 3D elements. Is the stair really not seen on the middle story? Or is it that you would not see all of the stair the upper and lower most sections being obscured by room on this middle story? If so, modeling the stair in sections so it would show only what is visible would be correct. Covering the upper and lowermost sections with a masking fill as David suggests would also work. The downside of the masking fill is it needs maintenance. You will be adjusting its visibility to be behind the elements that you want to obscure it.
-Consider also that the stair will most likely be built in sections if it spans 3 stories. We are creating virtual buildings; creating the stair in sections will mirror the real building.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
