Creating a stepped wall to follow a stair
I am sure I fell asleep during this class (as I often do).
Is there an easier way to create a stepped wall that follows a stairway than individually create a series of 12" long walls with each one increasing in height incrementally?
Thanks in advance.
4 Replies 4
assuming you're drawing the treads as slabs, use SEO to subtract with upwards extrusion to cut a wall to the bottom of treads? doesn't work perfectly if your treads overlap a little bit as is typical though.
have you tried stairmaker? there are probably others here with more knowledge of stairmaker than me...
wes
Do I understand....
This is with ArchiStair.
So archistair is very useful - what if i'm a student who doesn't want to spend 1800 south african rand on it. I'm new on archicad but still not sure how to build a stepped wall around a staircase without having to build each wall segment separately. am i missing something?
You can model the stepped top of the Wall as a Profile.
Assign it to a Wall and SEO the top of your Wall with this Profiled Complex Wall.
