2025-10-09 09:20 PM
Hello, I think I have found a bug in the Bluebeam connection when creating Sessions from Archicad 29.
Environment
Observed behavior
Expected behavior
Additional notes
Request - Please investigate and either:
I can provide screenshots, exact session URLs, account details, and logs if needed. Thank you for your help.
Best regards, Filip
Operating system used: Windows 25H2
2025-11-13 05:38 PM
We have the same issue. We are in the UK. I presume it connects to the US server, so we can't sign in at all. I've not used the bluebeam connection at all before, so learning the ropes with it.
2025-11-14 10:27 AM
You can claim at Bluebeam to change the region of you subscription .. so it solve the issue
2025-12-01 06:04 AM
Same issue here (from Australia).
Changing Region with Bluebeam is not an option for us.
There needs to be an option to select the region when you sign in - same as what appears on their website.
2026-03-16 05:23 AM
Will there be any update to this?
Graphisoft said they will address it in the next update, but it is still not working.
Anyone else have any luck?
