GREJX
2D DWF Export
Hi all.
I need to send my large 2D construction set to a client via a DWF file. publisher does this for each layout, however I need 1 consolidated file. I read that if I do this as a simple Save As, it will save the model space view? Does anyone know of a way to export to DWF, essentially merging my layouts into the 1 file?
Thanks
Josh
You can publish them as a single DWG file, then use Autodesk DWG TrueView, which is a free app, and it may be able to convert the DWG to DWF:
https://help.autodesk.com/view/TRUEVIEW/2026/ENU/?guid=GUID-8F32FA5B-AA4A-469E-87B7-8E5E6163596F
