Hendo
DWG file import cannot be edited
I have recently merged a .dwg file but I am not able to edit it at all. Layers are unlocked but still no joy. Probably a simple answer if you know it, like everything with AC. Using AC25.
Any help would be appreciated
CosminF
Did you explode the dwg? If you merge it you can move/crop/ rotate it etc. but in order to edit individual parts you need to explode (right click - explode into current view).
https://community.graphisoft.com/t5/Collaboration-with-other/Importing-DXF-DWG-files-into-Archicad/t...
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
