Curtain Wall - Rotate frame elements
Hi there
Is it possible to rotate the horizontal framing elements in a curtain wall so they align with the horizontal plan (or whatever plane that is desired)? I've attached an image that might help answer my question.
Thanks
1 REPLY 1
Hmooslechner
Curtain walls are "real systems" and parts cant be rotated, unless you create really new parts (in reality)
But there is the possibility in Archicad to apply your own polygons for the framing. You design the frames by yourself and apply it to the Curtain wall
