Greg Kmethy
Curtain Wall in ArchiCAD 12 - examples
Dear Talkers,
Here is a nice example for the creative use of ArchiCAD 12’s Curtain Wall tool from James Bowers of Bermello, Ajamil and Partners, Miami, FL. If you have similar examples, please post it in this thread. We would be happy to feature some of the best on graphisoft.com.
Gergely Kmethy
VP, Customer Success, Graphisoft
36 Replies 36
Link wrote:
... I made my name from the curtain wall tool while playing around with it some more...
In the spirit of Sarah Palin (well, really Tina Fey's) "And I can see Russia from my house!" ... and I can make my name with MEP ductwork! 😉
Seriously though... I'm impressed, Link. 🙂
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Link
laszlonagy wrote:
I suppose each letter is a Curtain Wall Panel created by joining several other panels, while all other panels and frames are set to invisible.
Actually, it's all one curtain wall. I just added these as polygons to the original frame boundary, then deleted the original. I'm surprised that we (AFAICS) can't cut a hole out of the boundary, as we can with a slab. This could be a way of inserting one curtain wall inside another, for example.
Thanks Karl - I know how hard you are to impress!
Link.
can someone please show me how can i make this (i mean the Curtain Wall made by James Bowers, Bermello, Ajamil and Partners Inc. )
i'm using archicad 17
pleeeeeeeeeeeeease
Check this clip:
https://www.youtube.com/watch?v=enm2xNrKquU
It shows you how to create a polygonal Curtain Wall. You should create that long nice curve of the Curtain Wall with linear and curved segments when defining the Curtain Wall polygon. You can then go to the 3D Window and rotate your Curtain Wall 90 to its desired position.
so i can create this louver skin using a lot of sun shades and then i delete the panels in between ?
Yes, I think you can do that.
You can select any panel and press the Delete key to delete them. This way you can have no panels.
OK thank you appreciate it!
