Curtain wall edit
Hi there,
I am wondering why can't I editing curtain wall boundary in a section or elevation view? just can do that in 3D. view. Seems like everything is locked. but I can edit the other things like frames and panels. But not the scheme. the only thing I can do in the scheme is moving it.
Thanks.
2 REPLIES 2
Hello Zhihao 1990,
Each type of view allows access to specific and appropriate commands. The interest is not to edit the object despite either. In a sectional or elevation view, it is possible (in some cases) that the curtain wall is partially visible. Editing it via this type of view therefore involves a risk. Different views are also tools that should be used correctly to get the best result. For example, a point of a mesh can be configured in 3D relative to another point (subjectively) or in 2D with a precise altitude coordinate. Two views = two objectives for the same logic > the best result !
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Christophe wrote:
Hello Zhihao 1990,
Thanks for your reply, I totally understand what you mean. But how come in some case you will be able to edit the boundary via a section or elevation, and how come in this case it is uneditable? that's something i am so confused about.
