Eli_Gravlax
Curved edge of Fill not smooth in 2D
Hi everyone, sorry if this has been answered elsewhere but I'm trying to fix an export of a curved fill. I've got a ring around a sign which I've done in 2D fill. Before I export it to PDF the fill is fine but then in the PDF the fill segments out making the edges of the fill not smooth. Anyone know how I can fix this?
Top: In the PLN
Below: in the PDF after exporting
In the PLNIn the PLN Segmented Export fill in PDFSegmented Export fill in PDF
ryejuan
under document options in your publisher you need to set the arc resolution higher.
WINDOWS 11 PRO
