‎2010-05-18 04:12 AM
‎2010-05-18 04:18 AM
‎2010-05-18 04:24 AM
‎2010-05-18 04:54 AM
s2art wrote:I did a search, but its not all that east to find I guess.
Pretty easy to do with Custom Profiles - lots of information on this forum if you do a search, or within Archicad's help files.
If the top of the wall slopes along its length use a roof to trim using Solid Element Operation.
‎2010-05-18 05:19 AM
allegronea wrote:Try also searching for Complex Profiles and just about any post by Dwight Atkinson.
No way to do this without using Solid Element Operation?
That tool is needed too much..
‎2010-05-18 06:32 AM
allegronea wrote:Sorry, yes I was a bit vague. Try THIS ARTICLE for starters (which is neither a forum thread OR in the Archicad help files - my bad) but was referenced by Dwight HEREs2art wrote:I did a search, but its not all that east to find I guess.
‎2010-05-18 01:35 PM
s2art wrote:Ah, I see what you mean with SEO.. misunderstood you the first time.. that makes more sense thank you.
... and SEO will only be needed if your walls are NOT a constant height along their length.
It would be handy to know your Archicad version too. Add it, and other system info to your signature.
‎2010-05-19 02:03 AM
‎2010-05-19 03:23 PM
‎2010-05-24 06:54 PM
