ā2010-05-18 04:12 AM
ā2010-05-18 04:18 AM
ā2010-05-18 04:24 AM
ā2010-05-18 04:54 AM
s2art wrote:I did a search, but its not all that east to find I guess.
Pretty easy to do with Custom Profiles - lots of information on this forum if you do a search, or within Archicad's help files.
If the top of the wall slopes along its length use a roof to trim using Solid Element Operation.
ā2010-05-18 05:19 AM
allegronea wrote:Try also searching for Complex Profiles and just about any post by Dwight Atkinson.
No way to do this without using Solid Element Operation?
That tool is needed too much..
ā2010-05-18 06:32 AM
allegronea wrote:Sorry, yes I was a bit vague. Try THIS ARTICLE for starters (which is neither a forum thread OR in the Archicad help files - my bad) but was referenced by Dwight HEREs2art wrote:I did a search, but its not all that east to find I guess.
ā2010-05-18 01:35 PM
s2art wrote:Ah, I see what you mean with SEO.. misunderstood you the first time.. that makes more sense thank you.
... and SEO will only be needed if your walls are NOT a constant height along their length.
It would be handy to know your Archicad version too. Add it, and other system info to your signature.
ā2010-05-19 02:03 AM
ā2010-05-19 03:23 PM
ā2010-05-24 06:54 PM
