cremsberg
Custom Door Panels
How do I insert a custom panel into a door? I believe I have correctly built an object for the custom door panel using slabs, and placed it in my loaded library, and re-loaded my libraries. Now, how do I make this new object selectable as a custom panel? I have tried this in Doors from both AC11 and AC12. Attached is a snapshot of my Door Selection Settings window. Note that the "Custom Panel Name" parameter has drop-down list with only a check mark. Should I expect to see my new panel library parts listed here?
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
6 Replies 6
Erika Epstein
You need to define the subtype correctly as a custom door panel. Then it will be available to select where you show in your screenshot.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
cremsberg
Erika - I was looking for an opportunity to "define the subtype", but I did not see it. Am I using the right command to create the panel library object? In AC12, I am using the "Libraries and Objects / Save Selection As" command. I am using an AC11 door. Thanks.
Claire Remsberg
cremsberg
So, is the command I need "Save Custom Component" and then select "Custom Door Panel" from Component Types options? After re-loading the library, it was still not available in my Door Settings parameters. Oddly, the Component Types list had two apparently identical options for "Custom Door Panel" and I've tried them both.
Claire Remsberg
Erika Epstein
Claire,
I saved the parts as an OBJECT and then changed the subtype per the attached
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
and then the door panel was available.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
rgarand
I am reviving this post. We are getting the exact "checkmark" when we make a custom door panel and then go to look for it in the custom door panel list. We see the gsm file within the embedded library.
The original file was teamworked and we saved it to a pln, the same thing happens.
If we open a new template and create a custom door panel everything works fine.
I tried your process Erika and this did NOT work. We created a custom door panel...saved as an object and then redefined the subtype with no luck. We still ONLY see the "checkmark" in the custom door panel list.
Any other thoughts?
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
