2011-11-14 04:34 PM - last edited on 2023-05-23 04:40 PM by Rubia Torres
2011-11-14 05:45 PM
Steven wrote:Yes.
Do I have to go to my original slab and edit that, then save it again...?
2011-11-14 05:51 PM
2011-11-14 08:31 PM
Steven wrote:You're welcome. Yes, either use a special layer for these things, or you can save them as module (MOD) files, delete the content and then just merge them in when you need them again. Personally, I do this pretty rarely, so just use a special layer. If the custom panels are used in other projects, each of which might customize further, then using modules can be helpful.
Ahhh, ok, thank you.
Because slabs can only be constructed in floor plans, these "bits and pieces" will have to be "floating" around the model, correct? On a non-plot layer of course...
