2022-07-08 08:30 AM
Hello!
I`m struggling to find if there is a way to make roof edge in shape like I have drawn in attached image. I can see that Archicad offers different types of roof edges but I need a different one. Please see attached image.
Solved! Go to Solution.
2022-07-08 08:42 AM
That is not one of the standard edge types that you can choose.
One way to achieve that is to use the vertical edge and use a slab at the correct level for a Solid Element Operation to cut away the bottom.
Put the slab in a hidden layer - unless you have an eave lining at that level, then you can use that for the SEO instead.
2022-07-08 06:06 PM
This is probably not the answer you were looking for, but you could also make a PROFILE that fits on the PERPENDICULAR cut end of the roof....
2022-07-08 08:42 AM
2022-07-08 06:06 PM
2022-07-11 07:59 AM
Thank you for your help! Both solutions worked for me!
2022-07-11 08:22 AM
If your roof is a single pitch and is rectangular, you could also probably use a rafter object?
