Custom tree bitmap in AC13
Hi everyone, I was just trying to use some custom pics of plants in my project. I did everything as said in this tip ( http://www.archicadwiki.com/CustomBitmapPeople?highlight=%28CategoryLibrary%29 ), but somehow it doesn't work. I saved pic as both .GIF and .PNG without background, loaded it into embed library, but when I type its name in designated place and close the settings dialog, AC lets me know that it wasn't able to find pic with that name. What am I doing wrong? I'm attaching both pics so someone can check if I did that 'masking' correctly. And yes I tried to find program's own bitmaps and see how they are masked in PS, but i can't locate them.
7 REPLIES 7
David Maudlin
Images not attached, try again.
You might try the image's name both with and then without the file name extension.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tried, same result
.rar atached
another one, png this time
Would you mind attaching a jpg or png? These two files types are visible in the forum without the need to download. Thanks.
Regarding AC not finding the file: double check using an independent file viewer such as Explorer or Finder that the file name and location is where you think it is.
This post is a similar issue with trees.
I just repeated the ArchiWiki and got this result in AC13:
Well files are just too big, but never mind. I think I overcome the problem by creating a semi transparent material and assigning it to a thin wall. Because of the distance it won't be visible..... I know it's a butcher's way but it did a job
Not a butcher's job, I use this technique as well, it is a nice render technique and saves on render time. Here are some trees made with slabs, some are glass and others are just a solid green. They cast shadows which was my primary goal for a sun study. I avoided all the render time of real trees.
David Maudlin
Višnja:
To get your image to work in AC13, I converted the Gif to Tif and added a alpha channel. [The original gif works as is in 17, so there appears to be a change to the way masking is handled.]
