Custom tree bitmap in AC13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-08-04 01:11 PM
‎2013-08-04
01:11 PM
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-04 01:33 PM
‎2013-08-04
01:33 PM
Višnja wrote:Images not attached, try again.
I'm attaching both pics so someone can check if I did that 'masking' correctly.
Višnja wrote:You might try the image's name both with and then without the file name extension.
but when I type its name in designated place and close the settings dialog, AC lets me know that it wasn't able to find pic with that name.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-04 02:02 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-04 02:05 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-04 06:32 PM
‎2013-08-04
06:32 PM
Would you mind attaching a jpg or png? These two files types are visible in the forum without the need to download. Thanks.
Regarding AC not finding the file: double check using an independent file viewer such as Explorer or Finder that the file name and location is where you think it is.
This post is a similar issue with trees.
I just repeated the ArchiWiki and got this result in AC13:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-04 06:36 PM
‎2013-08-04
06:36 PM
Well files are just too big, but never mind. I think I overcome the problem by creating a semi transparent material and assigning it to a thin wall. Because of the distance it won't be visible..... I know it's a butcher's way but it did a job
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-04 06:56 PM
‎2013-08-04
06:56 PM
Not a butcher's job, I use this technique as well, it is a nice render technique and saves on render time. Here are some trees made with slabs, some are glass and others are just a solid green. They cast shadows which was my primary goal for a sun study. I avoided all the render time of real trees.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-08-05 02:37 PM
‎2013-08-05
02:37 PM
Višnja:
To get your image to work in AC13, I converted the Gif to Tif and added a alpha channel. [The original gif works as is in 17, so there appears to be a change to the way masking is handled.]
