We value your input!
Custum slab
Hi
I need to make a PEVA 45 reinforcement in a concrete slab.
Is there any way to do a slab with custom profile?
It is possible with walls beams an roofs. Why not slabs???
I saw a ads on called slab maker.
se : http://www.masterscript.nl/3d-objects/49-custom-slabs.html
I think something like that is what i need.
Is there any other alternative. like a free alternative? this adds on cost money.
thank you
5 REPLIES 5
Floor Plan Display > Structure > Cut Fill
You use the composites manager to create the composites.
Oh, and I should add in the composite manager you have to activate the composite for the construct you want to use it on. See attached pic.
hi
Thank you for posting
I meant in 3D.
like a custom profile for slabs.
I want it to be a 3d object to show the direction of the reinforcement in sections. it is important
I am using this custom made Profile as BEAM:
Yes i thought about that. the problem is that you have to make a individual profile for each room. And if you have a round house then it is not possible.
