Cutting Lines Custom made stair
I just created a new Custom made 3d stair with the 'create stair using selection' button. It appears on my screen, but the cutting line isn't correct, it cuts the stair at like 300 mm above floor-level instead of the floor plan cut plane of 1250 mm. My floor plan cut plane is correct and I cannot find a way to select the correct cut plane of the custom made stair.
What should i do? Thanks anyway
1 REPLY 1
While you are in the stair dialog box (i.e. the one where you edit an individual stair), you can just drag the break line (cut line) to where you want it.
Richard
AC26 (since AC6.0), Win10
