Cutting holes out of fills
Occasionally I want to cut a series of hole out of a fill, e.g. where I've flooded tiling over a roof in elevation or plan, and then need to cut around the roof vents.
I've noticed that, when I select the fill, and then the 'minus' from the pet palette, sometimes, I can work my way around the fill cutting first one hole and then another. Other times (and this appears to be totally random!) after cutting one hole, I have to return to the edge of the fill and click the 'minus' on the pet palette after each hole before I can do the next. This is a pain, but I can't find any reason why it works one time and not the next.
Does anyone have any clues?
David Maudlin
Keith:
If you have the Fill Tool selected in the Info Box, and select the fill, then any shape drawn inside the selected fill will cut a hole (no need to use the Pet Palette). This method also brings up the second Pet Palette that allows curved edges to be drawn as part of the hole.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
That simple?! Thanks, David
