DOME PROBLEM
i want to build this dome
any help appreciated
12 REPLIES 12
You could solve this with "Complex profile"
I hope my screenshot shows how
Here's an resizeable object, might also be helpful.
PS. Updated the object -> the previous had wrong height
Vivi,
Your image appears to show a segmental dome.
To get the smoothest dome shape I would try
making the dome with Profiler using the revolve method.
Peter Devlin
Link
Okay, I'll ask the obvious question here - why not use the dome geometry method of the roof tool?
Link.
Hello Link,
I will give, what to me is, the obvious answer
I hate all those roof edge lines in the plan and in 3D.
The roof is not smooth like you can get with the Profiler object
or the Dome object and smoother than what you get using
complex profiles in AC 10. Maybe in AC 11 things are different
now that complex profile walls and beams can be curved.
Vivi's signature indicates that she is in AC 10.
Cheers Link,
Peter Devlin
Link
Yeah.... things aren't different.
Link.
thank you all very much!!! but can anyone tell me in simple steps how profile manager works???? sorry its the first time i need it
thank you for the object but still i cannot change its height
its a standard half sphere i need a piece from a sphere.
thank you very much anyway
Erika Epstein
You could cut off what you don't need with the a roof, trim-to bottom, or SEO.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
