DWG/DXF Translating
Help!
I have been working on secveral dwg files for over a week, files that I opne modify and save out again as DWG files. I have been opneing them without difficulty until today. A file I opened, worked on, saved and tried to re-open several hours later will not open (spinning beach ball). Now, all my other dwg files are doing the same. Some will eventually open, but hwre it took 2-3 minutes, now takes 10-15.
I have re-booted the computer, exchanged Archicad Add-Ons: Translators folders, but same. Archived all xml translators and used default. Same. have noticed the default save is Acad 2000 in my default translator.
Any ideas?
4 Replies 4
Djordje
Can you ZIP and post one here so that other can try?
Something is VERY heavy in your file; look at the file size. I suspect fills.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje-
It is not huge (2.6meg). I will zip one and post.
Problems continue. here are two files I am trying to open that came from a consultant. One is a native Archicad file, the other a dwg file made from same Archicad platform that created the native file. Whne I try to opne, I get nothing, nadda, zip on the dwg file, not even an error message. On the native file, I get "unknown file version". I have always been under the impression that PC and Mac .pln files are binary compatible. Is this not the case????
i would have thought that I could open a dwg created by any Archicad version, or have I got a corrupted something????
Since the files are too large to post, would someone send me a private essage w/ an email address to se if they can open??
thanks
