‎2004-05-28 08:24 PM
‎2004-06-03 05:01 PM
Link wrote:On the Mac there are the Keyboard Viewer and the Character Palette which are exceeding cool
You can utilize your Character Map (Start> All Programs> Accessories> System Tools> Character Map) to copy any kind of character you want. This is pretty much the same thing as Stefan said, except with a pretty GUI. Mac has the same thing, I just can't reall what it's called right now.![]()
Link.
‎2004-06-03 05:10 PM
‎2004-06-03 05:38 PM
‎2004-06-03 05:39 PM
‎2004-06-03 07:03 PM
‎2004-06-03 07:14 PM
‎2004-06-03 07:22 PM
i can't' find the Character Map in the Program/Accessories/System Tools. i'm using xp home....help!You probably don't have it loaded. You will need to go to Start>Control Panel>Add or Remove Programs>Add or Remove Windows Components> select Accessories and Utilities from the list and hit the 'Details...' button. Then select Accessories form the list and hit the 'Details...' button. Place a checkmark next to Character Map from the list, then hit all the OK's.
‎2004-06-03 07:54 PM
Link wrote:This is new to Panther (along with Font Book) and is one of the coolest of many cool features. It is easiest to get at by enabling the input menu in the International System Preferences as shown in the attached screenshot.
Hmmmmm. Well that's not what I remembered. Did this change with a later release of Mac OSX? It was called something different too. What you have shown is obviously much better and looks like the perfect solution. For future reference, how do you access these?
I have attached an image of what XP's Character Map looks like. Of course each map is different for different fonts, and if you select one, it will show the keyboard codes (look familiar Stefan? Sorry about blowing your cover!The XP Character Map looks pretty much as I remember the one in Win2K. Perhaps Longhorn will have copies of the cool stuff in Panther.). For anyone using these for the first time, you can only use these 'alt+' codes with the Numeric Keypad - not the numbers across the top of your keyboard, so make sure your NumLock is on!
Link.
‎2004-06-03 07:56 PM
‎2004-06-03 07:57 PM
