BradJAllen19
Delete original object when using Multiply command
When I am laying out windows or lighting in a room I often use the Multiply command to ensure that they are either centered perfectly in the room (when only one) or evenly spaced (when more than one) without having to do extra math to figure it out.  I place the object in a corner and use the 'distribute' function in the multiply command with the '-1' tick box checked.  It works great accept that I have to then go back and make sure I delete the original element.
I have searched high and low for an option which will delete the original when the copying is complete but can't find it. I'm sure there is someone out there who knows the answer to this question because it seems so simple that there is no way that this isn't an option for it right?
Please tell me I'm just being dense and overlooking an obvious thing.
Brad Allen
Designer
Ironwood Manufactured Homes Inc.
Archicad 26
Windows 10
0 Replies 0
