paveko
Deleting a morphed line that is connected to the other morphed object as a one
Both line and morphed roof show as one object, thus I can't select only line to delete it. I have tried using boolean operation subtract but when I click on it it says  'non-solid elements were not subracted'. When I click on solidify it says that one or more elements couldn't be solidified.
What else should I try doing?
URGENT
1 Solution
Set your selection to to 'sub-element' selection (I think CTRL+SHIFT is the keyboard shortcut while selecting - it will toggle between a white/black cursor).
Then select just the line and delete it.
If you can't delete it, you can set it as a 'hidden' line in the morph settings so you can't see it.
Go to post
paveko
Thank you, the first option worked.
