‎2024-01-13
11:16 AM
‎2024-12-31
04:23 PM
Molinda Prey
Both line and morphed roof show as one object, thus I can't select only line to delete it. I have tried using boolean operation subtract but when I click on it it says 'non-solid elements were not subracted'. When I click on solidify it says that one or more elements couldn't be solidified.
What else should I try doing?
URGENT
Solved! Go to Solution.
‎2024-01-13 11:23 AM
Set your selection to to 'sub-element' selection (I think CTRL+SHIFT is the keyboard shortcut while selecting - it will toggle between a white/black cursor).
Then select just the line and delete it.
If you can't delete it, you can set it as a 'hidden' line in the morph settings so you can't see it.
‎2024-01-13 02:20 PM
Thank you, the first option worked.
