Deleting favorites
Is there a way to delete saved favorites? For example a wall favorite saved in the wall default setting.
Thanks, Jim
Never mind, I found it. I guess I should look a little harder.
Jim
You can from the Favorites palette. (Window menu -> Floating Palettes) Highlight the favorite and select Delete from the flyout at the top. It's not possible from the element settings dialog.
Try keeping the Favorites palette around. By double-clicking a favorite, you can instantly activate/set up a tool, or change the settings of a selected element. Very convenient. You also need the palette to save and load favorites.
HTH,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Yes I saw that, thank you James
Jim
