Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Design software in Italy?
i have a small question:Does anybody know wich program is used in Italy for design?(REVIT OR ARCHICAD)
THANKS
4 REPLIES 4
Djordje
AFAIK:
ArchiCAD was used in Italy even before it was called ArchiCAD ... so the tradition is there.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
THANKS!!!
MORE OPINIONS,PLEASE...
http://www.graphisoft.com/products/where_to_buy/europe/italy.html
You can ask the Graphisoft distributor in Italy.
They are CiGraph.
If you look around you will also see that CiGraph has made a lot of Add-Ons for Archicad, so the relationship between the companies is quite old.
thanks a lot!!!!
