Design toolbar is missing
I use AC11. I need to make use of the trussmaker tool, but i dont have the design toolbar, or the trussmaker tool anywhere. I looked in 'work environment' and neither are there.
Any ideas
15 Replies 15
What do you mean by 'looked in'?
Try resetting your work environment to one of the Archicad defaults:
From the menu bar:
'Options' -> 'Work Environment' -> 'Work Environment'
Then select 'Standard Profile' and 'Apply Schemes of Profile'.
Dwight
Trussmaker, thus:
Dwight Atkinson
Tom,
Yes, thats what i mean by its not there. I applied the standard profile and it still wasnt there.
Link
Have you loaded the TrussMaker Add-on?
Link.
Im the only one in the office that doesnt have it, and nobody has done any special installations
Link
Well that doesn't really answer the question.
Check your Add-on Manager from the Options menu (assuming it's there! ).
Link.
It's there, and it was checked, but clicking 'OK' didnt do anything
Link
Okay Mr. Hammer. Then the next logical step is to check the menu in the Command Layout Scheme of your Work Environment, to see if the TrussMaker commands have been included.
Link.
Still not there
